Wider Front Tires?
danicol12
Marlette, MI
I have an L3560 HST-LE. I'm looking to put wider front tires on it for better flotation, as the fronts seems to cut into the lawn a bit. I currently have Titan Trac Loader 10-16.5 R-4 tires on it. I know I need to keep the same rolling circumference, and I'm comfortable with switching to turf tires (looking at the Garden Galaxy Pros potentially). However, I'm wondering if someone knows of a wider front rim that will work on the Grand L's without rubbing at full lock, and while allowing a bit wider tire. Thank you in advance!
4,274
This thread reminds me of a joke about 3 nuns that went to heaven and St Peter met them at the Pearly Gates.
He required each nun to answer a Biblical question correctly Before they could enter Heaven.
He asked the first nun, Sister Theresa “Who was the First Man?”
Sister Theresa replied, “That’s an Easy One! It was Adam!”
Immediately Trumpets Sounded, Bells Rang-out thru the Heavens, and the Pearly Gates Opened…and Sister Theresa walked into Heaven.
St. Peter turned to the 2nd nun, and told Sister Patricia, “ Your question is, WHO was the First Woman?”
Sister Patricia replied, “Oh, That’s an Easy One! It was EVE!” …and Trumpets Sounded, Bells Rang, and the Pearly Gates opened up and Sister Patricia walked into Heaven.
St. Peter then turned to Sister Marie and inquired, “and What did Eve Say when she First Saw Adam?”
Sister Marie replied, “Oh! That’s a Hard One!” … Trumpets Sounded and Bells Rang and the Pearly Gates opened up and….
Anyway…
Your question doesn’t appear to be common with a known solution. Sorry. Let us know what you find.
BAP
Dec 31, 2012
3,213
1,322
Anyway…
What in the world does this have to do with answering the OP’s question?????
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,387
908
under a rock
Cut into the lawn?? as in, Turf?
I assume you are not cutting the grass with a tractor of that size....
anyway, turf tires might help. but it's the nature of the beast... check air pressure and take it easy.
be thankful you don''t own a skid steer.
4,274
When does a “Joke” …become a “Dad-Joke?”
When it becomes apparent.
I thought it apparent that the question was a hard one to answer.
(After several days passing…. No one had given a response at all…and I didn’t want the new-comer to feel ignored.…and believed a little humor might ease the situation.)
