Where to get a ROPS for an older (85 and before) tractor?
JUSS10
Kubota B8200-HST
Mar 2, 2021
34
West Michigan
Recently bought a B8200 that I've fallen in love with. From what I can gather its an 85 and doesn't appear to have come with a ROPS when new. I contacted the National ROPS Rebate Program and they said the only option is to order one from a dealer. Contacted my local dealer and they said they can no longer order a ROPS for my machine.
I had a father who almost died in a tractor roll over accident and as a father of two little ones, I would like to have the bar for safety as well as for adding a light bar and flashing light for snow removal in the winter. Is my only option to find a used one from a salvage yard? I've done some looking at salvage yard inventory in my relative area and no luck. Are there any companies making aftermarket certified ROPS so I can still get some rebate money?
Justin
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
You might have some luck speaking to people that fabricate roll cages for cars. They may have some ideas.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
Hello JUSS10,
Is this of any benefit? Doesn't look like they have one made for your particular tractor, but they do have a universal model.
Good luck with this.
Donystoy
Dec 10, 2013
651
289
Binbrook, Ontario
I just fabbed one out of 2 inch tubing in an evening for a fraction of buying new.
69 SS
2015 L3901 HST,with Canopy,LA 525 FEL with SSQA bucket
Sep 26, 2015
106
22
Ft. Inn sc
Hey, had the same problem as you mine was an 85 Ford 1710. Looked on ebay until I found a later model 89 for sale that had a roll bar on it and bought it from the tractor seller. He took it off put it on a pallet and shipped it to me. Kind of expensive with the shipping, total cost was like 365.00. Really good insurance for me. Hope this works for you.
5,532
It'd be nice to have diagram/pictures of a real one.. in case you have to get one made. It might be hard to get one custom built AND certified though. Not sure HOW they test them to get the 'seal of approval' and I don't think you want to loan your out for the 'roll over test' !!
1,709
Look at the Kubota USA website and they did have a program that provided ROPS at reduced cost. You may look under safety or something similar in the website.
https://www.kubotausa.com/service-support/safety/tractor-safety/rops-safety
You need to fill out some form with the serial number from your tractor. Then Kubota sends information to you and you order the ROPS through your dealer.
You can have the dealer have it delivered on their normal stock delivery and save shipping cost (I think). Dealer can install or you can.
If you’re not able to locate the information on their website post back and I’ll see if I can find it or not. The link I provided looks like a dead end on an iPad but see if it works on a PC
JUSS10
Kubota B8200-HST
Mar 2, 2021
34
West Michigan
Tried this. Got to the point of having to order it from my local dealer and they said they could no longer get them and the part number isn't available anymore.
I do have a friend with a tube bender who makes roll cages for rock crawlers and jeeps so needless to say I could come up with something. Just thought I'd check here if there was something I missed before going the route of a custom build.
Good idea on finding someone with a B8200 that HAS a ROPS so I can have them show me exactly how its mounted.
Donystoy
Dec 10, 2013
651
289
Binbrook, Ontario
There should be four threaded holes in the rear casting on either side lower down. I would think that the B8200 is the same. I fastened a 1/2" plate to these areas and mounted the ROPS to this. My mount is incorporated into the full upper and lower frame I built years ago to accommodate my BH that included a new stronger top link bracket.
JimmyJazz
1,253
783
Pittsburgh, Pa
Look on Tractorhouse.com under dismantling. There are quite a few tractor junkyards in existance. Good luck.
