Wheel weights
Turfturd
B7510
May 20, 2021
53
Missouri
Has anyone found a good place to buy wheel weights for B series tractor. It looks like the holes are 7 3/8” apart and there are 4 of the. It does look like the wheel weight can only be 12” in diameter.
thanks for any help.
SDT
multiple and various
Apr 15, 2018
3,383
1,162
SE, IN
Try North States. They make weights for Kubota/others and are less expensive than manufacturers weights.
They do not sell retail so you will need to work through a dealer.
Most tractor/implement dealers can get information and pricing. Whether your dealer will choose to do so or not is another matter.
SDT
thirdroc17
185
35
I've always wound up making my own. Standard, flat, barbell weights are getting hard to find, but by selecting a weight that fits nicely inside the wheel and drilling a few holes has worked well.
The ones I'm running right now, I built mounting brackets to bolt in the wheel, with a single center bolt. Then bought round steel plates and drilled a single hole in the center. This packs the most weight within the outside tire wall.
3,325
Agreed, like this:
