wheel spacers
2,914
Does anyone know if 2 inch spacers will fit my bx2380, if i am using 54" midmount mower deck?
The problem occurs with the wheels on the deck rubbing the rear tires as the rears are pushed out.
IF you look and measure carefully you will see how 2" extension on the rears wheels will affect this.
Usually when you raise the deck the anti-scalp wheel will hit the rear tire when using the 54" with too much spacing - you may need to use 1 1/2" spacers.
armylifer
Mar 26, 2013
2,250
1,010
Thurston County, WA
I have a BX1860 and I have 1.25" spacers. If I went any larger, then the right rear tire would rub on the 54" mower deck. There is very little size difference between your tractor and mine. Especially since i upgraded my tractor tires to the same size as what came stock on your tractor.
