what oil to use?
jerrell
tiller, B6200, B6000, 2 bottom turning plow, 5 ft bush hog, frail mower 5 ft,
Jun 23, 2013
beebe, arkansas
I got the B6200E with a tiller about a month ago and i used it to till up about 1/3 acre, ran like a champ no noises and did an excellent job, i got me a manual and changed oil, hydraulic fluid, and changed oil in tiller. i have two questions, what oil do you use for the hydraulic oil and what oil for the tiller. i ussed 80/90 oil in tiller, and used TSC premium hydraulic oil for tractor, while tilling today the gears was more noise than it did the first time i tilled, and the oil i drained from tiller was so thick it took 30 min to drain and i had it upside down to completely drain, . I'm just wondering if the oil i used in the hydro and the oil in tiller was thick enough, both looked sorta thin for the job they do.
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
34
Alberta
If its a hydrostatic transmission, use Kubota UDT or equivalent in the trans. If its gear driven, use 80w90 gear oil unless it has external hydraulics added to it, then use the UDT. Use 80w90 in the tiller.
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
Even with no external hydraulics (like FEL, backhoe, rear controls), there is still the 3 point, which uses the trans as a holding tank for the fluid. So shouldn't it always be hydraulic fluid in the trans? And my impression (from reading, not experience) is UDT for HST, and any good brand hydraulic for gear drive.
olthumpa
L275
May 25, 2011
1,501
Maine
My L275FL 4x4 standard trans, (8 forward & 8 rev), calls for UDT. My HST's call for UDT. That keeps it simple for me, just keep UDT on hand for all my tranys.:cool:
I do not know if UDT is called for in all standards but I believe it is.
If in doubt call your local Kubota dealer.
I use 85W-140W in all my implement gear boxes and have never had a problem. I also use it in the front axle of the L275.
Hope this helps.
freewheel3
Mar 9, 2013
333
34
Alberta
I know how everybody gets sensitive when it comes to oils on this site but I'm only going by what Service Dept Vic says in one of his videos about Trans oil changes that is posted on here. Basically he states that if you don't have a FEL, then you don't need to use UDT in a standard trans, but its not going to hurt if you do, its just unnecessary. Also, you wouldn't want to put a straight hydraulic oil in the trans, you would have to use either gear oil or a combination (TDH trans, diff, hydraulic) fluid such as UDT. I'll try to post a link to the video.
http://www.youtube.com/watch?list=PL583A232CA2DA4923&v=WeaolHWdslg&feature=player_detailpage
BadDog
Jun 5, 2013
579
Phoenix, AZ
Wow. I'm not one of the hyper sensitive guys, but I never would have thought 80W90 in the trans given that it feeds the hydraulic pump for the 3 point lift. I know there is not that much difference, but just as he says in the video, there are differences, so I just went along with the "always use a rated hydraulic oil" school of thought. Doesn't matter for me personally because the number one reason I bought a tractor was the loader, so I need normal hydro fluid anyway.
Also, much thanks for the video. I had been pondering whether that inexpensive hydro flui from Wally's would be ok for my aging (and growing apparently :D ) fleet. Looks like according to him it is, and that's good enough for me, so that will save a few dollars.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Just remember cheap oil is cheap for a reason, low quality. Not saying it won't work but don't expect in to perform like a high quality lubricant does.
Bluegill
Jan 11, 2012
1,559
Success Missouri
I always used 80/90 gear oil in the trans of geared tractors with no FEL. My newer rigs w/FEL get Kubota UDT2.
BadDog
Jun 5, 2013
579
Phoenix, AZ
In some cases, I completely agree. But in these days of MBA "branding" and such, it's not uncommon for the generic (whatever) to be from the same batch as a high priced "branded" product with no difference but the label. The problem is, identifying them to start with, and it may change when names (brands) get bought, or when another bidder undercuts. I just can't see paying to the high priced Kubota fluid in my beat old gear drive (I would for HST), particularly when there is no hard evidence supporting the value. I would also pony up if it were something I based my livelihood on, or even something I planned on spending a lot of time working. But that doesn't apply to my use on my little property I've been wrong before, and I'll be wrong again, and I've changed my mind over time on many things, but I doubt I'll ever see any evidence on my tractor that proves one way or the other on this topic.
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
Your tiller may have had 0,00,000 "pourable grease" I dont know what brand of tiller you have but King Kutter does not use 80-90.
The universal oil is known as HT its meant for trans and hydos ,Regular hydo fluid is strictly for hydos and not tractors that have one reservoir for everything.
jerrell
Jun 23, 2013
beebe, arkansas
I just hope i didn't mess up, I used TSC's top quality 80/90 in the tiller, it doesn't have a sight hole nor dip stick (has chain drive on R side, Mashio brand) so i filled it up to about an inch from the top, about 2 gallons,
i used TSC top quality hydraulic oil for the tractor's transmission and 3 pt lift, took 14 quarts, on the 5 gal bucket it stated for Kaubota and many others. i have a Belarus that uses 30 w oil for tranlny and 3 lift.
It just seemed the oil for the tranny for the Kaubota was a little thin to me. i used premium diesel oil for the engine . i just hope the oil for the tranny is thick enough, it makes a squeal when i lift the tiller, would it be wise to put a little 30 w in the tranny to thicken it up, or do i need to change to all heavy weight for the tranny, i sure don't want to mess up the gears. the little tractor and tiller is a real workhorse.
Bluegill
Jan 11, 2012
1,559
Success Missouri
You are probably fine, but I would have gone to Kubota for the trans oil.
Any good diesel engine oil will be fine.
I have no idea about the tiller. My first thought would be 80/90?
freewheel3
Mar 9, 2013
333
34
Alberta
You keep saying you used TSCs hydraulic oil in the trans. If its a straight hydraulic fluid, drain it out and replace it with either a universal TDH (trans, diff, hydraulics) fluid or 80w90 gear oil. You don't want to use straight hydraulic oil in the trans.
Bluegill
Jan 11, 2012
1,559
Success Missouri
Yes to that! :cool:
BadDog
Jun 5, 2013
579
Phoenix, AZ
Sorry, I'm new to this. Earlier when I said hydraulic, I meant the TDH as recommended in the video.
Drew584
Kubota L3800DT W/FEL, and 60'' LP Brushhog
Jun 17, 2013
38
Mannford ok
I would ask your kubota dealer when in doubt, I recently changed all fluids on my L3800DT (gear drive w/FEL) and the dealer recommended kubota UDT for the trans/hydraulics. They said if it was hydrostat then run the UDT super. I would think the 80/90 for the tiller would be fine. Is there a manual for the tiller?
Bluegill
Jan 11, 2012
1,559
Success Missouri
I run Super UDT 2 in mine and I have gear drive. That is some very good oil!
jerrell
Jun 23, 2013
beebe, arkansas
OK , called Kubota dealer, and was told the oil i used , Premium Hydraulic lil from TSC would work, explained the situation to him and he insured me the oil was safe and since i live so far from a dealer , gonna try it , works good so far, used the tiller again yesterday to run over the garden area and everything working OK/ thanks for all the info, if i ever get close to a Kubota dealer will pick up some from them for next change out.
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Your Kubota could be as early as a 1983 model. At that time they were using SAE 80 gear oil for the shared gear drive/hydraulic systems (from my M4500 operators manual circa 1985). Later rec is for a multipurpose hy-tran fluid like UDT.
There will be more gear noise with the thinner oil no matter how much you pay for it or who makes it.
Down side of a gear oil in a hyd unit??? It foams and traps air bubbles with extended use making the hydraulics seem spongy and slow.
Down side of using UDT or a compatible (of any brand) in an older gear drive tranny??? More noise (but it won't hurt anything).
