Well Used Bush Hog
DaveFromMi
L3901, 5' Bush Hog
Apr 14, 2021
550
466
Indiana
My kid does metal working and repair. This was dropped off today. It's a 6' Bush Hog brand, heavy duty. The stump jumper literally fell off.
ken erickson
Nov 21, 2010
1,007
1,569
Waupaca Wisconsin
Sounds like a good project! Will your son/you be posting work in progress pictures? Any plans for restoring/replacing the deck?
4,102
so...... it fell off AFTER your kid did the work ???
or...
he'll be DOING the repair work !
English is great language...you can read it both ways......
DaveFromMi
L3901, 5' Bush Hog
Apr 14, 2021
550
466
Indiana
Lol, it fell off after hitting a big rock. I think his plan is to pound it back in shape with the help of a torch. After that, patch up where the blades went through with sheet metal.
He just finished modifying the front end of a light duty rotary cutter.
1,951
Good for him!
That looks like a big project for sure. It looks like it's gonna take a decent amount of "gas and pounding".
I think I'm too old for that, but I wish him well.
Smokeydog
Jun 2, 2020
572
530
knoxville, Tennessee
Address the issue with the gearbox spline and blade carrier hub before worrying about the deck. Blades shouldn’t contact the deck like that.
GrizBota
Apr 26, 2023
1,141
727
Oregon
lol. My “lightly used” Land Pride RCR1860 had the stump jumper crack all around the pivot point for the blades. My good friend has done much welding on it over the years. It’s on its second gear box, second set of skids, second tail wheel frame, third tail wheel, third set of blades (maybe fourth?).
Mine doesn’t have a ridge in the deck from the blades hitting the deck, but I do believe the blades can flex a fair bit under heavy use (some might say abuse?). Or the T bar under the stump jumper may have a bit of aftermarket ground contact induced adjustment. Keeps the upper edge tips of the blades sharp I suppose :unsure:
Tim Horton
250
42
Lake Superior
WOW..... I'll bet that was a surprise when it happened... If it were my mower, I would get another one.. Then depending on cost, fix, sell the old one to retrieve some value from it..
