I have welded cast iron many times. Complex fractures are very difficult to keep aligned during the process, and it can be difficult to manage the heat on complex pieces that have varying thickness.
Managing heat is key. Once the crack is prepared (ground with a "V" along the crack for adequate weld penetration), I heat the pieces in a forge or even a BBQ grill until they are uniformly cherry red. Have your clamping set-up ready to go ahead of time, and then quickly clamp and weld before the pieces cool. I'll have a wire brush handy to brush the ash off the cracked surface before clamping. Then, as soon as you're done welding, toss it back on the fire, and let the fire burn out, ideally over several hours. You want the piece to cool off as slowly as possible after welding. You have maybe 5 or 10 minutes at most to do the work before returning the piece to the heat.
I use a mig welder with regular solid steel wire (0.030" or 0.035"). My mig welder is a Hobart 185.
Again, you'll have the best success if it's a simple crack and the pieces have uniform thickness. I've had complex pieces simply crack in another place while welding due to poor heat management. Thinking of that Farmall F-12 belt pulley I tried (unsuccessfully) to fix. I also think that older pieces are more of a challenge due to the primitive metallurgy.
One thing to be aware of. The weld is SUPER hard. So, if there are threaded bolt holes along the crack, you will never be able to drill them out or re-thread them if there is weld bead in there. The only other 'machining' I've tried on cast iron welds is grinding. That's usually not too challenging. Die-grinding the weld, even with carbide bits, is not very productive. You can scratch at it, but not really cut it.
Another thing to be aware of. Cast iron that is heated up to glowing gets quite soft. Crumbly would be a better word. So, don't go beating on it with a hammer before it cools back down, or you'll break it again.
Maybe try it on a junk piece of cast iron before you tackle your project.
If you successfully manage the heat, after welding, the repaired piece is every bit as durable as it was before.
It's actually quite satisfying to 'save' a piece this way!
Good Luck,
-Paul
