Weight bracket
Grizzy3901
L3901hst, la525, 72" landpride finish mower
Jan 1, 2017
67
Bealeton va
Hey i have a new L3901 and im looking for a weight bracket for the front or do guys just hang them on the grill guard bracket.
Thanks
Yooper
3901 LA525
May 31, 2015
1,682
843
NE Wisconsin
Just curious why you want weight on the front? Most owners, including me, find that the back end is where the weight is needed.
bucktail
Jun 13, 2016
1,276
198
MN
The front can get pretty light with some of the 3 point attachments. With my L1500, I can get the front wheels off the ground with the dirt scoop or the boom and I suspect that they'll come up with the disk I have for it as well. Granted, I'm on the smaller end of the spectrum, but still.
Grizzy3901
Jan 1, 2017
67
Bealeton va
Going to be running a disk to redo my field. Also thinking about making a "ripper" pretty much just the tines off a box blade with no box just to help remove roots and all from overgrown areas on the edges of my feilds.
Grizzy3901
Jan 1, 2017
67
Bealeton va
No im making it for the 3pt just want to keep the front tires down to keep it pulling good making something like this
Yooper
3901 LA525
May 31, 2015
1,682
843
NE Wisconsin
OK, got it. How much weight do you think you will need?
Grizzy3901
Jan 1, 2017
67
Bealeton va
Not sure all the ones i see are 55 pounds. Guesa id start with three and see what happens.
mdhughes
L3901DT
Dec 10, 2014
1,398
1,273
Ste Geneveive county, MO
Grizzy3901, are you going to be doing this with the FEL off or just the bucket off. The FEL frame without the bucket adds a lot of weight to the front end by itself.
Grizzy3901
Jan 1, 2017
67
Bealeton va
When i go to disc the fields then probably going to keep FEL on i have an extra skid steer plate i might make so i can hang big john deere weights on and pulling that pasture renovator probably off bc im in some tight areas.
4,576
I wouldnt be to worried about it my self but if you do have a FEL just fill it up
