New to the forum and new to owning a tractor. Purchased a used B1750 with a loader a few weeks back. The loader and PTO works but is very weak. Had a buddy that’s worked on tractors and actually owns 3 Kubota tractors and A Kubota zero turn mower. He recommended that we change the hydraulic pump so ordered and installed a new one. The pump was only producing around 700 psi at 2000 RPM with the old pump and the new one is doing the same. We blocked the line going to the power steering from the hydra block and the loader and PTO works perfect. At 2000RPM it had 2200PSI. So we downed the steering and inspected and can’t see anything worn or damaged. We cleaned and re-installed and it still doesn’t work. Does anyone have any suggestions for us to look at next? Any help would be appreciated.
I have attached a pic of the hydraulic block I’m speaking of.
Thank you
Thank you
