The cooling fan is wobbly with lots of play in the water pump pulley, and coolant is leaking through the weep hole on my B7200. It needs a water pump.
I can replace the defective pump with a genuine Kubota water pump for around $250 from Messicks, Colemans, etc. Pricey.
I can replace the defective pump with a no-name aftermarket water pump for around $50 from Amazon, Ebay, etc. Much less costly, but I'm concerned about the quality (or lack thereof) of these pumps.
Or I can repair/rebuild the defective pump with a genuine Kubota bearing/shaft and seal from Messicks, Colemans, etc. for about 75 bucks. Doing this doesn't look to be any different from water pumps I've repaired before. Just need a decent hydraulic press and some extra time.
Any additional thoughts on which repair might be the most desirable?
