Wasps/Hornets under a deck, but can't get under the boards
legbuh
bx2680
Sep 28, 2020
19
mn
We have our 2 car attached garage with a deck on top of it. Those little hornets have been living under those boards forever. We just got the whole deck redone with trex and now that it's warm, we can see they are building new homes.
There is about 2-6 inches between the deck boarding and the roof above the garage (there are angled floating shims under the boards to level them, and still allow water to flow down to the gutter.
What would be the best way to get rid of them? I was thinking some sort of powder I could sprinkle on the deck then sweep into the gaps to get under there.. but I don't want it to stink real bad or hurt the rubber roof under the decking.
thanks for any ideas!
Bmyers
May 27, 2019
3,392
4,132
Southern Illinois
We had yellowjackets that were building nest in our garage walls. I used Delta Dust Multi Use Pest Control Insecticide Dust, 1 LB with a Harris Diatomaceous Earth Powder Duster with 6 Inch Extension Nozzle.
Pumped it in the holes at night and three days later, all were gone. I have also used it to control ants by pumping it along the edge of the house and windowsills.
I'm guessing it would work for your needs, but I'm not an expert, just my experience with the product.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,299
Somebody has to give the sensible response. It might as well be me!
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
658
995
Hayward Wi
I have a similar deck on front porch and have had similar problem. What I found works for me is watching where they access the underside of board and lay a thick bead of foaming wasp/hornet spray in the gap area from a distance. They seem to always use the same access space to get to the nest. They are pretty dumb too, theyll fly right into the foam spray on deck.
The foam holds up for awhile so you have to reapply every 5 min or so but it knocks them off.
legbuh
bx2680
Sep 28, 2020
19
mn
Ya, that may work. Until it rains. Then I expect the powder will all just wash away down the gutter. :) worth a try!
5,130
I would not be concerned about any powder or liquid insect killer damaging your EPDM roofing.
That stuff is almost "bullet proof".
  • Dislike
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,504
1,950
Western MT
If you can see the nest, wasp spray foam. Worse case very quickly make an opening after dark.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
628
580
Indiana
See where they are going into the nest during the day. Spray with a focus on that area at night. I like Raid Wasp and Hornet Killer. It has a longer stream than the foams.
legbuh
bx2680
Sep 28, 2020
19
mn
It's a deck.. there are many places they are going in an out between the gaps.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
I am deadly allergic to bee sting. Wasp got under my front door sill. I called the local pest control and wrote out a check. It took them several tries and a couple of different chemicals to get the little killers.
The people with the skill and big time chemicals can do wonders.
jimh406
Jan 29, 2021
2,504
1,950
Western MT
Good call. Nothing to play with if you are allergic.
I'm the opposite. I barely have a reaction from a sting. I guess all of those years as a kid of catching different kinds of bees in my hands and putting them in jars. Fyi, I'm not allergic to poison ivy/oak either last time I was exposed. NOTE: I don't try to get stung or play in poison ivy/oak any more. ;)
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Beware, Mother Nature is a cruel mistress !
I got stung often as a kid and never had an issue. In my late 40's I ran over a nest with the mover. Four quick stings and I did not worry. A few hours later and I was in the ER trying to breathe. Three stings since, with one to the ER and two to the doc-in-a-box. I have epi pens all over the place and I run like a little girl when I see a nest.
Wasp, hornets, and honey bees are scared to death of the wife..... my protector.
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
224
198
Bella Coma BC Canada
The yellowjackets start getting active when we are running the cider press while making apple cider we use a heavy duty shop vac to suck them up, then spray a couple of shots of Raid in to hose while it is running at the end of the day.
Toyboy
May 18, 2010
658
995
Hayward Wi
I'm getting allergic to yellowjackets. Those miserable little wasps take no prisoners if you get close to the nest. I ended up in the ER from a reaction of getting stung on my ankle. Neck broke out like hives and was swelling up.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Many of the wasp & hornet sprays contain mineral spirits which will destroy an EPDM roof. The water based ones will be safe to use. Read the label.
1,710
There is a dry powder called Demon sold at Tractor Supply here. It comes in a foil packet and inside are little packets of the powder. You use one packet in a pump up sprayer and then the packet dissolves and you mix it in water.
Spray it into the cracks between the decking and it will dry up. The wasps should die off as they crawl across the residue. I use it to spray the foundation and outside walls of my home and do not have any wasp nests on the eaves or walls that stay active.
You may be able to find a spray tip that will fit between the boards and spray the underside of the boards also?
Velma
B2301, FDR1660, RB1560, SGC0554, Pats QH, CMP Dethatcher
May 12, 2022
92
57
MI
Could try a couple traps also. Win by attrition.
motionclone
May 4, 2018
1,399
996
Maine
Similar situation here. Got stug plenty as a kid but at about age 30 got stung by one yellow jacket and basically died then brought back to life by medics then in icu for a day. Had severe Anaphylactic shock. never heard of it before but since i have had a bug radar and very careful about venomous things. Im fat but i can run like a tuned athlete when i run into a hornet situation..lol
