Wanted:Steering Box for a B8200HSTD
ecook280
Kubota B8200HSTD
May 1, 2012
34
I am in search of a working used steering box for a B8200HSTD, mine broke over the weekend moving dirt and the parts I need to repair it are no longer available, so does anyone have a used one available?
garyrthome@frontier.com
B7200 hst with FEL B8200hst w westendorf fel and chink BH
Ligonier IN
I have a allmost new one but I don,t think you going to like the price I paid for it to be used as a spare :):) I ave $500.00 plus shipping
ecook280
Kubota B8200HSTD
May 1, 2012
34
Still looking, Gary wasn't sure if his was the right part #, thanks for checking Gary.
Ligonier IN
are you still looking for a gear? my spare is 66361-41110 and the arm is 66361 41410 Gary T 260 634 1410/ 260 564 4247 cell
ecook280
Kubota B8200HSTD
May 1, 2012
34
Parts diagram shows mine is a 66301-41100.... so close, thanks for checking the part numbers Gary
ecook280
Kubota B8200HSTD
May 1, 2012
34
I just did some digging Gary, that gearbox is for a B9200 with a serial number under 52071. The drawings look identical and they do use the same bearings gaskets and o-rings but the rest of the parts are dif numbers. Can you get some measurements off of it? If its close and will bolt in I would still be very interested, who knows maybe its just a little longer or something. If you can get me the measurements center to center on the mounting bolts, front to back and side to side, and length of the column, that would help.
ecook280
Kubota B8200HSTD
May 1, 2012
34
Hi Gary, tried to call a few times, busy and now says cant be completed as dialed, tried your cell as well, left you a message, I was out on the road but am home now
ecook280
Kubota B8200HSTD
May 1, 2012
34
Thanks for all the help Gary, I appreciate it more than you know, I sent you a PM with the information we talked about.
Thanks so much for everything
Eric
7,265
Is the steering box different when comparing a HST to a manual shift tractor? I found the box I took off my B8200 when I installed power steering. It manual shift, if that makes a difference.
ecook280
Kubota B8200HSTD
May 1, 2012
34
I did get one off a 9200, the gearbox bolted right in, the column was an inch shorter but it fit. I did have to use my pitman arm as it was longer than the one from the 9200 which had clearance issues.
