Wanted: Loader for L3650
NWAZL3560
L3560, LA805 loader, BH77 backhoe, rock bucket, box blade, pallet forks
Jun 11, 2018
128
58
Mesquite, NV
When I bought my L3560 1 year ago the loader options were the LA805 or LA555. Might help you in your search. I realize you're looking for a L3650 loader but might be close.
9,708
Looking for a loader attachment for a L3650, thanks
It would really help to know where your really located as option that are too far away from you aren't really options! ;)
9,708
Sorry, but not close at all, like 25 years of technology different. ;)
Dodger
L3650
Mar 24, 2019
30
Sudbury
This one in Pennsylvania would be perfect but 10 hours away, a bit too far.
Is there any other options for the L3650 other than the LA650 loader ?
I'm located in Northern Ontario Canada
9,708
Yea there are several other manufactures that make loaders that will fit it, you don't need to stay with a kubota loader. ;)
9,708
I have a 1016, but finding one of those is going to be hard, and finding the right mounting brackets will be even harder.
You might want to see if the newer LC96, LC102, LC108 and the right mounting brackets are available for your L3650.
Dodger
L3650
Mar 24, 2019
30
Sudbury
will I need a subframe or do the loader mount brackets just bolt up to the frame ?
Have a line on a LA524 , will need to alter the mounting brackets but would I be to make this work ?
9,708
You would have to make the sub frame and axle bars, for it to work.
I can try and get a picture of my Wood's loader set up if that would help you?
Dodger
L3650
Mar 24, 2019
30
Sudbury
Yes that would help a lot, do you mean bars to the front or to the rear axle ?
Plus I have a cab also so that will complicate things a bit , but if it's doable with some subframe and mounting fabrication then I will probably go ahead and purchase the LA524 loader.
9,708
That model of loader is going to be really hard to fab up the sub frame because of it's mount design.
I'll take some pictures and point out the problems. ;)
Dodger
L3650
Mar 24, 2019
30
Sudbury
If you could show me what you mean with some pics, that would be great Wolfman, before I go out and purchase this LA524, thanks
9,708
I'll take pictures of it tomorrow for you. ;)
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
try the buhler brand he makes them under three different names : allied is one name good luck manufactured in winnipeg mb and grand forks nd good luck
