Voraga
armylifer
Mar 26, 2013
2,338
1,089
Thurston County, WA
The only way to tell for sure is to read the product specification sheet or the MSDS (Safety Data Sheet) for this particular product and compare it to the Kubota specifications.
3,177
There is currently not a Kubota UDT2 fluid, it was replaced by the fully synthetic SUDT2. I believe that UDT is “crude oil“ base, SUDT was blend of crude/synthetic and SUDT2 is fully synthetic.
So currently the Voraga UDT2 will (probably) not be the same as Kubota SUDT2 since Kubota UDT2 was not the same as Kubota SUDT2. It may be a great blended oil but it would probably void the warranty of a new tractor that requires the use of SUDT2 (or equivalent).
11,429
I see Amazon lists a Voraga UDT2 transmission fluid. Is this product any better or worst than regular Kubota udt2? Thanks
The VORAGA It's a listing typo.
In Canada you don't use SUDT2 you use premium UDT (it's the same as SUDT2).
armylifer
Mar 26, 2013
2,338
1,089
Thurston County, WA
The following is from DDG AI
Kubota UDT2, also referred to as Premium UDT in Canada, is a mineral-based hydraulic oil. This means it is derived from natural mineral oils and is designed for general use in various hydraulic applications.
Comparison with SUDT2
In contrast, Kubota Super UDT2 (SUDT2) is a full-synthetic formulation. This synthetic oil is engineered for better performance, especially in extreme temperatures and modern hydraulic systems.
No code has to be inserted here.
Both fluids serve different purposes, with UDT2 being suitable for older gear-drive tractors and SUDT2 recommended for modern HST equipment.
11,429
There need to be a:
HUGE WARNING: this is AI generated BS on the above info:
This is not AI INFO:
UDT is the original hydraulic fluid for Kubota.
SUDT was a 50 /50 blend of synthetic and Mineral and has been obsolete since the 2000's.
There is no such thing as UDT2
SUDT2 is a full synthetic Hydraulic Fluid
In Canada they can not market SUDT2 because of a copyright / name / patent conflict so it's marketed as premium UDT.
7,422
There need to be a:
UDT is the original hydralic fliud for Kubota.
SUDT was a 50 /50 blend of synthetic and Mineral and has been obolete since the sealt 2000's.
Careful with those terms.
SUDT2 base oil is 100% petroleum distillate. It contains no Group IV oil. Source - the Ashland MSDS
How much of that distillate qualifies as "synthetic" in todays world is anybody's guess.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
570
191
NZ
Spec sheets can be fabricated like anything else. Voraga doesn't seem to have much history either.
7,422
As I said in post #3, when I looked all I found was third party listings for genuine Kubota SUDT2. AI seems to have now caught on
Voraga UDT2" (often looked up as voraga sudt2) refers to a third-party seller product listing on platforms like Amazon and eBay containing genuine Kubota Super UDT2 tractor transmission hydraulic oil. The name "Voraga" is simply the brand name of an online e-commerce merchant or reseller rather than a separate oil manufacturer. [1, 2, 3]
armylifer
Mar 26, 2013
2,338
1,089
Thurston County, WA
I hate AI but it seems that we cannot get away from it.
7,422
In this context "AI" is nothing but an automated summary of search results. It suffers from the inherent weakness of all computer algorithms - garbage in -> garbage out. Thankfully Google lets you turn it off.
JohnDB
Jun 9, 2018
570
191
NZ
Voraga UDT2" ... refers to a third-party seller product listing on platforms like Amazon and eBay containing genuine Kubota Super UDT2 tractor transmission hydraulic oil. ...
Your AI, like mine, is simply regurgitating what the ads say. It's almost certain that the stuff is nothing like "genuine" in meeting Kubota actual spec, proven by testing by an accredited laboratory.
7,422
John,vforget AI and go look at the ads. Its a third party listing for genuine Kubota SUDT2 in original Kubota packaging.
JohnDB
Jun 9, 2018
570
191
NZ
Agreed, including "genuine" in the ad proves that it is ;).
I emailed the Kubota fraud address and asked them if it's counterfeit but no reply. It smells dodgy... ad says that weighs 2.5 ounces, for 2.5 gallons. Voraga has little history on line. I'm willing to be proven an untrusting old fart.
Possibly Kubota takes the approach that if you can't beat 'em, join 'em:
https://www.ftc.gov/news-events/new...-penalty-against-kubota-false-made-usa-claims
