v1902 Manuel - parts & service
ziegler
Scat Trak 1300HD
Feb 9, 2015
Buffalo, NY
I have a Scat Track with a v1902-81501 that I am replacing all (4) injector (blows more diesel than it burns, they pop at 125 bar) and head (2 middle cylinders are cracked and valves does not seal). Have not found a replacement for the injector copper washers yet?
Are there any parts/service books available? So fare most of the parts numbers I have found were from ebay or New Holland L553/L555, Bobcat 301/743, Carrier generator, trunk refrigeration units. Being the motor is on an engine stand already and I ordered a full gasket set, I plan on removing & cleaning as much as possible and putting on the new gaskets.
I ordered a new thermostat off e-bay but have not found a replacement oil temp light switch, oil pressure light switch and coolant temp light switch, coolant hoses. Try NAPA but the guys could not be bothered with me, looks like AutoZone may have generic flexible cooland hoses that may work.
Thanks.
9,128
For parts you could look at parts for both a Bobcat 743 or a Kubota L3450, they both take a V1902 engine.
Go to Kubota.com and look in the illustrated parts to find all the parts you need, If you still can't find what your looking for PM me and I'll get you the Part #'s.
