V1505 not getting fuel past the pump
Cmcnair55
V1505
Jun 3, 2022
Minnesota
Hello, I have a kubota v1505 on a wood mizer sawmill. I cannot get fuel past the injection pump, I have replaced the glow plug relay and the shut off solenoid and still have no luck. Any advice would be much appreciated, thanks!
JerryMT
Jun 17, 2017
529
154
The Palouse - North Idaho
Do you have a CONTINUOUS flow of fuel to the inlet of the Injection pump (IP)?
11,372
Have you tested the inputs to the shut off solenoid?
whitetiger
Nov 20, 2011
3,816
2,217
Kansas City, KS
A very simple test, remove the fuel shutoff solenoid from the injection pump and see if it will run. That will tell you if you have a mechanical issue or an electrical issue.
Cmcnair55
V1505
Jun 3, 2022
Minnesota
So I still get no fuel after I removed the shut off solenoid and still have the same problem, what do I do from here?
