v-1902, leaking injector pump
Jim Cate
kubota v-1902 marine diesel
May 8, 2016
Manly, queensland, Australia
G'Day all,
I have a V-1902 engine, marinized by the Nanni co, in our sailboat. It has arou nd 5000 hours use, and has recently started leaking fuel around the delivery valve housing (for the #1 cylinder) on top of the injector pump. Engine runs normally.
There is an o-ring at the base of the threaded housing, and from what I can gather, it is a common failure point. I have been advised that while it is easy enough to replace the o-ring, it is highly likely that the "fuel flow calibration" will be lost for that cylinder during the removal and replacement.
My questions:
Is that a serious worry?
Is there anything that I can do to minimize the chance of this problem occurring?
What is a good on-line source of a shop manual for this engine?
Any other advice?
Thanks from a new member!
Jim
9,779
That is a load of horse excrement! :eek: :p :rolleyes:
You can replace those O-rings without changing a thing well besides eliminating the leak and making the injector work better. ;)
1970cs
1,124
Grand Ledge
NIW is correct! Blow of the top of the injection pump or use carb/parts cleaner in a can. Since this on a boat with that many hours on it. I would get all 4 o-rings and delivery valve washers.
Shut off the fuel, remove all injector lines, remove the valve cap. Then I use a 1lb magnet to extract the body and plunger valve and then have a 90 degree o ring pick to pluck out the washer. As the service manual "assembly is the reverse of disassembly"
Turn on fuel, and bleed the injection pump and then lines.
Pat
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
G'Day all,
My questions:
Any other advice?
Jim
I think that's engineerspeak, for it'
ll miss till fuel starts pumping through the line, maybe 30 seconds, or so...
NIW is right, X2:D:D
Jim Cate
May 8, 2016
G'Day gentlemen,
Thanks for the advice. I'm happy to report that I successfully replaced the o-ring and washer as you suggested, and the engine runs normally, sans leak! For now I'm a happy camper.
Jim
