Transmission Chatter
Herow
l3240, bx1860
Jul 12, 2014
Bloomingdale, OH
I have a L3240, after brush hogging for about an hour, I was heading up grade with PTO engaged, the tractor stopped moving, and I coasted back down. I was in M Turtle.
I moved the shifter to low and back to high.
The tractor stared to move in M with a loud chatter which sounded like it was coming from under the fuel tank. All of the other hydraulics worked fine, PTO, Loader, streering and brakes.
Once I moved about 10 feet the noise stop in M and now it only makes is in H Rabbit, and if your in M Turtle and shift to Rabbit it chatters while engage to the high gear.
Any Ideas
Thank
9,171
What model is it?
There is a huge difference in problems between an HST, Geared, and GST model. ;)
9,171
Sounds like you blew out the clutch plate or pressure plate.
How many hours are on it?
