Trailer plug add on.
Camera Man
Kubota L5460, Kubota L2296Bucket,lde SGC1060 GRAPPLE, Landpride PFL2042 Forks,
Jun 27, 2020
Idaho
So I run a wood splitting buessnes and my splitter dumps into a 16ft dump trailer that I move with my Grand L5460 and a goose neck three point hitch. I have found I ether need to keep the dumps battery on a tender or jumped off another battery to dump more than a few times. The trailer is me,t to keep charging off the truck and even run off it. I want to install a 7 blade trailer plug just to run power from the tractor to the battery/power unit. Anyone have any thoughts?.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
It would certainly be simple enough to do but I have a concern about running your tractor battery flat. You should consider adding a battery isolation circuit.
BX23-S,57 A-C D-14,
5,890
gee I can get 2-3 dozen dumps before my battery needs charging, so your battery sounds 'weak'. Big thing is all connections need to be clean and shiny.
Adding the 7 pinner to the tractor is a very good idea, as it would allow you to also have LIGHTS for the rare time you need to be on the road( neighbour needs a load of ponypoop).
3,292
Just what I was thinking.
Camera Man
Jun 27, 2020
Idaho
New larger battery. We are dumping anywhere from 6-12,000 lbs. We went from a 550cca to a 750 cca. It's a 14gx big text goose neck.
With the snow on the ground I just don't need to be running an electrical cord across my woodlot hahaha.
BX23-S,57 A-C D-14,
5,890
re: With the snow on the ground I just don't need to be running an electrical cord across my woodlot
That's not a problem until the snowblower 'finds' the extention cord...... don't ask HOW I KNOW about that scenario.....
SidecarFlip
Banned
562
Sounds like my wife with her 110 volt hedge trimmer. That lasted oh, about 2 minutes until she severed the cord. It quit working honey... Gee, sweets, don't work with a 2 piece cord.... :rolleyes:
To the OP... Get a 1000 CCA deep cycle battery.
i7win7
Feb 21, 2020
3,377
3,991
Central, IL
If lights are not needed, cheep jumper cables and these connectors may work
Thunder chicken
M7060
Dec 29, 2019
300
123
Northern ontario
Camera man, i tow my dump trailer with the tractor. I removed the factory ag style 7 pin and put on an RV style one. Had to get the multi meter out to figure out the wiring. If I recall, there was no 12v constant like a truck. Or if there was, it was powered off the same fuse in the cab as the headlights, my memory is foggy on that.
I also seem to have issues with batteries in my dump trailer, getting only a few dumps per charge.
so what I did was put a quick connect hose block between the cylinder and pump. Made up hoses for the tractor. So when tractor towing, I hook the hoses up to a remote and dump it with the hydraulics. Easy to swap around for truck (electric) or hydraulic (tractor).
On my truck, I ran a piece of 4ga welding cable from the truck battery (through a solenoid and fuse) to a big Anderson plug, on the dump trailer side I have 4ga wire and a 40a self resetting circuit breaker. Seems to keep the battery charged ok. Ive been through many batteries, the next one will not be a deep cycle, I’ll try a big starting battery instead. I don’t know why I kill batteries with this trailer, was like this for the previous owner too. Maybe the pump motor is going bad?
At any rate the 12v trailer plug will only give you a few amps at best. It will not charge the battery like you need.
BX23-S,57 A-C D-14,
5,890
re: At any rate the 12v trailer plug will only give you a few amps at best. It will not charge the battery like you need.
On my F150 , I can get 15amps to the trailer,as long as the key's on, always 'tops up' the dump trialer battery. For a tractor setup, you'd need to run from the battery, though a 15A fuse then relay then the 7pin connector.Control the relay with 'switched' power form the ign sw. that way,trailer only gets power when tractor is running. Be SURE to connect tractor GROUND run the white GROUND wire of the connector !!! Without that ,you'll never supply enough current(power) to the trailer. The trailer ball is NOT a true ground.
603g5200
Kubota G5200G, G2500 snowblower and a Massey Ferguson MF20 Industrial
Oct 27, 2020
I believe that Kubota makes the plug connector for your tractor, it plugs directly into your existing harness in the rear. I know for the M series tractors they run about $30, cheap and easy way to get your power to your trailer. If the tractor is idling then it will charge your dump trailer battery. IF they do not make one then they are easy to make and you can buy all the connectors, wires and plug parts on the online store that starts with an A. all you need is your wiring diagram for your tractor , buy the same color wires, and build the harness.
