Tractor tires
Taylorwillis
L3750 1984
Nov 1, 2019
12
Hello I have a L3750 with turf tires size 42x25.00-20
it is due time for new tires and I'm needing some recommendations for some new ones. I am on the fence about either trying to find the same types of tires or changing out the whole rim. I'm having issues locating this tire so that is one of the reasons I'm looking for new rims. Let me know what you guys are running with and how much it cost you.
2,827
2wd or 4wd?
If you change the rear, will need to change the fronts too - unless it is 2wd, that you can do dang near anything you wish!
armylifer
Mar 26, 2013
2,144
914
Thurston County, WA
Have you looked at the dealer? I was surprised that the dealer sold tire and rims less than just what the tire would have cost me at Les Schwab Tire. This is not to say that Les Schwab is bad, they are most definitely not. I am just saying that buying the tires already mounted on new rims through Whole Sales at my dealer ended up being much cheaper than going to a local tire dealer. I have also seen tire and rim combinations on Amazon for reasonable prices. Check around, I am sure that you can find an appropriate tire and rim combination for a reasonable price.
Taylorwillis
L3750 1984
Nov 1, 2019
12
I guess you live where it is flat and dry. Otherwise lucky often means 4WD...
Up in the panhandle of Texas.
This is the tire and rim size TCT recommended, they couldn't find a rim size that would fit besides this one.
ITEM NUMBER ALR8917 16.9-24 R4 Titan industrial Tractor lug
Taylorwillis
L3750 1984
Nov 1, 2019
12
Just an update here, I went to the Terry Tractor Company here in Texas. They hooked me up with two brand new rim and tires for 2056.75 I went with the 16.9-24 R4 Titan Industrial Item number ALR8917
