Tractor PTO Sensor Plug
Orange Cab Tractor
MX6000
Sep 3, 2024
The above replies in the thread detail the component needed. A little plug for about 98 dollars from Kubota. If the female (tractor side) of the connection is broken, the PTO controller must be removed. It's just three bolts, but you must drain the entire transmission or else you will make a big mess in your barn;) The female part is only about 50 dollars. You need a "C" clamp to reassemble the controller. Otherwise easy-peasy.
I recommend everyone make some sort of belly pan to protect these dainty tractors from brush that you drive over when mowing. I have broken both the male and female parts of this connector. So, I will not drive it again until I make some sort of protective shield under the tractor. Next weekend's project.
Koehlersc
L4701
Oct 14, 2024
Fall Creek, WI
$94.00 for a new plug. Forget catalytic converters, addicts can start cutting plugs.
CattleFarmer13
Kubota L4701
Dec 18, 2024
Hawkinsville Georgia
After some interweb searching and following up on some of the leads posted on this thread I have a solution in progress, although it will take 16 to 17 weeks to show up.
I contacted a company called Corsa-technic.com and exchanged several emails with Sarah who did some research on the on the information referenced in the Furukawa catalog mentioned in this thread.
PN: UW-2S KIT
Terminal: UW-SKT
Seal: UW-SL
She located the parts and ordered them, now just waiting for them to arrive. The good news is she has had some other requests for this part(s) so Corsa-technic might be a source in the future, however I had to order 25 kits, that was the minimum order. The good news is the kits were only $4.85 each, a whole lot less that the new wiring harness my dealership said I would have to order ($4k).
If someone needs a replacement plug now, I will have extras in the near future. thank you to all who responded and provided guidance.
Hey Gunrunner308, I have just had this same problem and need a new plug, do you have any available?
6.5x47ShooTer
L4802
Jul 2, 2025
Western NC
I know this is an older thread but I joined this forum because of this same issue I had with my 4802.
Has anyone successfully made some sort of protective part to shield this delicate piece of plastic?
I’m thinking building my own bracket or pan to fit around it is a necessity at this point. Luckily the wire only pulled out and I got it back in but I don’t want to break that cheap connector and have to go through the hassle of trying to get it fixed.
If anyone has made something to protect that connector on their tractor I would love to see what you did.
