Topping off 4wd gear box
Bill8200
B8200
Oct 12, 2020
35
PA
I need to top off the front gear box on my 4wd. It holds 2 quarts, but if I’m topping off, how do I know when it’s full? Can it be over filled?
loggin
MX4700
Sep 4, 2021
111
39
canada
Yes it can be overfilled and if it is you will likely wind up blowing some seals. Typically front axle cases are only filled about half way. There is a plug that is removed where the oil can flow out once you reach that level.
Here is a video of an oil change procedure on an L series which is a little different than yours but the principal is basically the same.
I hope this helps!!
Bill8200
B8200
Oct 12, 2020
35
PA
I hope this helps!!
Cool, thanks!!
