Top link spacing in quick hitch ?
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket,
May 4, 2026
41
31
Missouri
Is it normal on a Kubota to have space/play side-to-side between the top link and the quick hitch upper bracket? Don't think it would be an issue but wanted to know if that's normal. Thanks.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
222
265
Stafford, VA
I used washers to equally fill the gap in both sides of the top link… others may not care, while others probably have the correct bushing to use and merely cut it to size to center it. I had the correct sized washers sitting on the shelf and problem (possibly only a perceived problem) resolved. Since the clientele here is broad ranging and absolutely great at coming up with solutions from simple to exquisite, you should also read and evaluate their two-bits and pick your forward path.
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
293
698
wisconsin
it doesnt hurt anything there is no side load on the top link if everything is adjusted correctly. it will self center as needed when movement and vibration of use is happening
