Top Link Measurements LX2610HSDC
Oldmanbs
LX2610HSDC, LA535, LX2963, Land Pride back blade, B-422 tiller, posthole digger
Jul 27, 2021
14
Buffalo Minnesota
Hello all, I am purchasing a LX2610HSDC to replace my Simplicity Legacy Xl Diesel, the new Kubota will have rear service and I’m wanting to purchase a hydraulic top link for it for box blade and rear blade with hydraulic angle, so I am inquiring as to the factory top links specifications length closed and length fully extended.
Thank you in advance for your valuable time and information. Brian, aka Oldmanbs. Have a great day.
nbryan
Jan 3, 2019
1,170
712
Hadashville, Manitoba, Canada
I believe my B2650 is the same basic machine as your LX2610, so likely a 3-point top link will be the same?
Mine came with a 18 1/2" - 27" range top link range, measured at pins center-to-center.
Oldmanbs
Jul 27, 2021
14
Buffalo Minnesota
Thank you for your quick answer, I do believe that they are very close. Again many thanks for your time and information. Brian.
MtnViewRanch
719
176
Lakeside Ca.
For a hydraulic top link, 18"-26" works well for all the B & LX series tractors.
Problem is to find one that has a 1 9/16" wide ball swivel for the tractor end.
Oldmanbs
Jul 27, 2021
14
Buffalo Minnesota
Thank you for your help, if i cant find the correct width there are always shims or a grinder/end mill to correct that issue😉, but thank you for your input. Brian.
