Tires for a B7200D
Joe_C
northeastern Pa.
I am looking at buying a B7200D .
It looks like a tractor that has set around quite a bit, doesn't seem to show wear in areas where i would expect if it had been run a lot .
The hour meter show 205 hours , but who knows how long it has been since it worked last.
The front tires on the tractor are like new , as far as looking at the depth of the lugs ( lug type tractor tires).
However they are very badly checked/dry rotted? both in the thread area and the sidewalls.
The front tires are Bridgestone , Farm Service Lug -M size 6-12 . 4 Ply
The rear tires look pretty good as far as lug depth ,and not checked as bad as the fronts.
The rears are Firestone , Traction Field and Road. F - 151 size 9.5-16
I was wondering what the original equipment brand tires/size were for this tractor.
Looking at a spec sheet from tractordata it shows this as a mix of sizes.
Origial equipment ag tires were 6-12 for the front , and 8-16 for the rear .
Optional ag tires were 5-10 front and 9.5- 16 rear .
Wondering if this is a "mis-match" of tire sizes for a 4 wh drive , or if the acutal diameters of these tires are ok .
Does anyone have a suggestion for replacement tires , especially for the front tires.
The tractor has a loader on it so i am thinking i should make it a priority to replace those.
I am still in the "barganing" stage with my purchase so the tire replacement costs will be figured in also.
Kind of looks like an average of $100 for a front , and $300 for a rear???
The only other problem i see with the tractor is that the right brake is "stuck" slightly in the on position .
It has a slight drag , and this might be due to the fact that the tractor was sitting for quite a while and the brake lever is rusted where it goes into the rear axle housing . (at least i hope that is all that is wrong.
thanks in advance for any and all help
Joe.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I don't see how the rear could either be the 8-16 or 9.5-16. There is quite a bit of difference in the height of these tires. the 8-16 and the 6-12 combo sounds right to me. I know that is the size my B 7100 came with anyway. If you do have the 9.5-16 size and the 4WD works then it has to be what you need.
Those prices that you listed sound high to me. I saw a add for two 11.2x24 tires the other day shipping and all was under $300 for both. Find you a Mom and Pops tire store and price you some there. The high priced name brand tire stores will try to stick it to you. Look at tires on E-bay. I have seen then on there at good deals before.
Woodswalker
B7100D(1977)/FEL, B7200D (1984), Yanmar RS 1303 tiller
Mar 5, 2014
15
Republic, Washington(NE), USA
I recently bought a B7200D that I think still has original tires.
They are Goodyear, and the 8-16 / 6-12 combo.
The fronts are badly checked, like yours, and one leaks.
Am also in the market for new fronts. Local Tire Factory outlet here has been very
good to me in the past, so going to see if they can order a pair.
