Can anyone help me determine if the rear tire valve stems on a Kubota ZD21F should be on the inside or the outside of the rim? The left rear tire has the stem on the inside. The right rear tire has the stem on the outside.
The answer may help explain another problem I have with the left rear tire rubbing a hole in the fuel tank. The ZD21 had fairly new tires when I bought it. I am beginning to wonder if the left tire was installed incorrectly.
Thank you
Thank you
