Tie Rods, Ends, & Boots
HS2
M4700
Sep 2, 2019
Houston, Texas
I have an M4700. The tie rod end boots on both sides have split. So has the boot on one of the tie rods.....
Nearest I can tell, the tie rods & ends are fine, but I know if I keep driving with broken boots they'll wear.
My question is how hard is it to change just the boot? I think I found some available......is it worth it to change just the boot, or should I go ahead and get a tie rod and tie rod end?
How difficult is this job? It looks easy, but I've never done it before.
Thanks
200mph
Mar 3, 2017
1,228
65
PA
Check the tie-rod for play before changing out the boot. If there is play, buy the new tie-rod, but sit down before seeing the price (about $130).
If tie-rod is ok, it is generally more economical to replace the boot.
Good luck
3,696
My M4700 has tie rod ends which are in good shape. (Only 500 hrs since new in 1996.). But, like yours, the boots were torn.
I didn’t want to go thru removing tie-rods and wheel alignment issues and I had some sheets of either Nitrile or EPDM (the latter is what the supplier claimed but it feels/looks like black rubber nitrile). This material was left-over from when I built my hangar-door and used long sheets of it for weatherseal on the door. (44’X14” length/width)
I cut squares of it, wrapped it around the tie-rods such that the edges over-lapped and allowed moisture (if any) to drain out the laps on the bottom, and sealed the ends using aircraft safety-wire twisted onto the ends of the “rolls” made by the rubber sheet. (You might also use durable ty-wraps but I preferred stainless steel wire.)
Two years later they are still in excellent shape, my tie-rods protected from dirt/water, and the lubrication/grease is retained where it belongs and I saved a bunch of money and time while getting the job done as well as the factory. I suspect the repair will outlast the original boots.
Hope this helps.
3,696
I should add that material was acquired in 2000 and is still like new. I imagine you could use some rubber gasket material from the local auto-supply house. About 1/8” thick worked very well for me, winding a couple of wraps of wire onto the ends of the over-lapped rubber-sheet, and then twisting the wire in a pig-tail. This is not a high-tech need for a tractor, you only need to protect it from moisture. ;)
