Tie Rod ends
chris989
L3450
Oct 5, 2016
35
boise
Hello All,
I have a L3450 and need of the outer tie rod end. My dealer says 175 ++ for just the end and ~350 for the assmbly (inner and outer)
I can not find the part number for the outer but the whole assembly # is 35080-44640.
I already cut the female coupling off so i can weld in just bout any 25$ moog joint easy enough. My taper is .640-.700 and the moogs are ~.600-700.
any advice where to buy at a reasonable price or where to find the correct taper?
If 200$ is the only option, I guess i will bight the bullet.
Chris
SidecarFlip
Banned
561
I did on my M this spring, 175 clams for the outer. I thought it was highway robbery myself and I really did after perusing Flea Bay and finding them for much. much less, like 50 a piece. The OEM ends don't have grease fittings either. The ones on Flea Bay do.
Needed a main shift boot and it cost me 29 bucks for a small ribber boot (OEM). Some prices are stupid high some aren't like filters. Bet the boot cost about 10 cents to make.
If you need the inner radial joint (my M has a radial joint inboard), that is 350 clams OEM. Never seen those on Flea Bay but tie rod ends, yes.
9,185
Need the exact model and serial number as there are several steering setup's on the L3450's. ;)
