Tie Rod dust boot for B2601
AndyW
2019 B2601 TLB
Jan 24, 2020
21
Kingston, WA
Sorta locked down here in WA state but getting work done clearing up the property - trying to locate a part number for the dust boot for the tie rod for a B2601 via the internet. Some of my interweb searching found a lot of discussion on the BX version and how the dealer only has the full tie rod as a replacement assembly unless you order the correct part number for the boot...but nothing I could find much on the 2601. Any help appreciated! TIA.
AndyW
2019 B2601 TLB
Jan 24, 2020
21
Kingston, WA
So these are supposed to fit and are an upgrade. Small price to try em out.
I'll post back my experience.
https://www.ebay.com/itm/Kubota-BX-GR-Inner-Tie-Rod-Boots-Upgrade-all-BX-models-Kubota-K1253-01660/252113476258
200mph
Mar 3, 2017
1,229
66
PA
Yes. Seller says it fits a B as well. Part number sleuthing at Messicks seems to indicate this is true.
Thanks for adding the clarity as it was obvious. I'm certain the OP will be appreciative of information.
KellyKubota
2020 B2601
Jun 15, 2020
North Carolina
Installed this today. Good product, easy to install, better protection than the original.
So I'm in the same boat as you... I just called my dealer and the new tie rod is about $75-$80 for my new B2601. I really don't feel like spending that kind of money. I just wanted to double check to see how well this seals behind the boot. It doesn't look to have a rind to snap it into place. Or does it fit snug against the joint?
Thanks for any info!
SidecarFlip
Banned
563
As much as I prefer Kubota OEM replacement parts, I won't buy OEM tie rod ends. The aftermarket ends are greaseable. The OEM ends are not (at least on my M9's they aren't and the aftermarket ones are substantially less expensive.
AndyW
2019 B2601 TLB
Jan 24, 2020
21
Kingston, WA
It has a ring and fits very snug.
