The stock foot pedal for thumb control was always awkward for me. Small and slippery since excavation usually involves mud. Big feet, age and poor dance abilities in need of solution.
First added cleated pedal extensions. Simply cut from 2x5” rectangle tubing. This gave height, length, width increases and boot traction. Length gave longer lever arm control from the pedal’ s return spring. Made the toe cleat slightly higher for better position. Made a world of difference in control.
Also added a hand control lever. Nice feature that gives good
fine control like for stacking rocks. Both options work well together and easy to operate. Still able to flip pedal up and lock function if needed.
After several jobs and hours of use has improved my thumbing ability. Pedal operation much smoother, easier with better control. Hand option integrates well with the other controls.
