Three Kubota B7100 HSTD tractors for sale
mradmono
B7100 HSTD
Jan 1, 2022
Houston, TX.
$2700.00, all three tractors are a package deal; I will not separate! Tractor # 1 is an early model B7100 HSTD 4-wheel drive. It has a front-end loader that works. The engine starts and runs and as a running engine, is worth at least $700. The transmission is in place but disconnected as it was inoperative; I have the used part ($1600.00 new from Kubota) to repair the transmission which is included. Tires hold air to move it andso will roll; also, front tires are new.
Tractor # 2 later 1980’s model B7100 HSTD 4-wheel drive. I bought it for parts although the tractor can be reassembled and returned to service. This was a working tractor and the engine was partially taken apart so a grandfather could show his grandson how an engine worked; he never put it back together. I believe the tractor parts all there except the radiator which is missing; However, I never inventoried the parts. The transmission alone on this tractor is worth at least a $1000.00. Tires hold air to move and it and will roll.
Tractor # 3 is an early model B7100 HSTD 4-wheel drive. It is a parts-only tractor!!! Has a short-block and transaxle installed but the transmission is removed. Many good parts are still on the tractor. Tractor will roll if the tires are aired-up
3,089
Sounds like a deal, but I have no more storage or room in my life for more projects,
Best of luck with your sale!
6,591
When you put your cursor over the moniker of the poster you will often find their location. in this case Houston, Tx. That's how I know you're in NJ.
