Thread Sealant on Head Bolts
MIKLAV1315
B7100D
May 22, 2021
11
Cleveland
Dear Friends,
Do cylinder head bolts and engine lifting loop studs need thread sealant?
Working on D750. Installed a new cylinder head. Purchased from KUBOTA new head bolts, cylinder head gasket, exhaust manifold studs, and studs for engine lifting loops. The only hardware that any type of thread sealant on them was the exhaust manifold studs.
Respectfully,
Mike from CLE
i7win7
Feb 21, 2020
3,377
3,991
Central, IL
Think I would use never seize on exhaust bolts/studs. Recently using it on mower blade bolts. Heard stories of old-timers using milk of magnesia (magnesium) to prevent bolts from siezing
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
55
North CA
On auto engines I just use a small coating of auto oil unless they went through a water jacket, than I used anti-seize on the threads. However, if possible check the SM if you have one or check with the dealer who sold you the bolts and stuff. Let us know what you find out.
Jim L.
872
172
Light coat of engine oil on head bolt threads. The reason is that the torque settings assume the light coat of oil. If they're dry, they won't set at the correct torque.
Motronic
B2650, Z421
Jun 3, 2021
60
44
PA
The torque spec assumes a light coat of oil if and only if it calls for a light coat of oil. Plenty call for dry and this absolutely makes a difference.
whitetiger
Nov 20, 2011
3,356
1,792
Kansas City, KS
Dear Friends,
Respectfully,
Mike from CLE
[/QUOTE
Use only engine oil if it is specified, in this case, it is specified.
