Third Function at 3 pt. hitch for tree puller
ALinCarolina
B3200
Aug 12, 2013
9
Weddington, NC
I have a couple projects in mind for my B3200 before spring arrives. I am going to try and fabricate a tree puller similar to this one that Ken Wetzel made on this video:
http://www.agriculture.com/videos/v/74602037/tractor-mounted-tree-puller.htm
Wish I was closer to him, seems like my kind of guy.
I also plan to get a grapple and install a third function for it on the front.
I'll have a lot of question as I go through this construction but for now I need to know what I need for the third function hydraulic for the rear. I'll ask for help later about picking out a cylinder.
I need to be able to use the 3 pt. lift same time that I use the hydraulic cylinder to close and hold the jaws. Does anybody make a kit for this? I assume it would be the same kit for a hydraulic top link. If no kit, then what parts do I need to order? My pump is 25 L/min I believe.
8,453
Yes there is a couple of stock optional kits to add rear remotes, they are not cheap most run $500+ to add them.
For little use consider running lines from a rear cylinder to a set of quick disconnect that will be run by the loader control valve.
And same goes for the Third function on the FEL for a grapple.
You can go through a local dealer to get the valves and parts or as most of us do, order the parts and install it ourselves, I use Coleman for almost all of my parts needs.;)
http://www.colemanequip.com/Kubota_Parts.asp
ShaunBlake
Dec 21, 2014
899
For little use consider running lines from a rear cylinder to a set of quick disconnect that will be run by the loader control valve....
Do you (would you) leave your loader mounted to do occasional jobs using the loader hydraulics on a rear-mounted implement? I haven't examined removing my loader, but from what I've seen, it's not trivial. (No paved spot, no level pad, etc., and no framework into which to park it.)
8,453
If you use the loader lift you need to block the rams from continuing to try and force fluid out the lines, even with a good set of couplers it can be difficult to hook them back up, so bad choice there.;)
But you can use the dump lines as they will have almost no fluid force on the couplers.
ShaunBlake
Dec 21, 2014
899
Thanks, that's clear and your explanation helps reduce the intimidation factor a bit.
ALinCarolina
B3200
Aug 12, 2013
9
Weddington, NC
Using the front loader lines might make sense to start with to at least make sure my contraption works before buying a valve. What if I just used the lines to the tilt function of the loader? I assume I would still be able to raise or lower the boom arms. Plus, moving the loader stick sideways would be moving the jaws of the implement in the same directions and be more intuitive I think. Am I correct?
