TG1860 Driveshaft Flex Coupling
jleickman
TG1860
Mar 21, 2026
Highstreet
The rubber discs in the driveshaft flex coupling need to be replaced. I'm finding it hard to lay down between $200 to $300 for a pair of flat round pieces of what appears to be conveyor belting. Yes, the mower runs great and it's worth it to keep it running but again, that's a lot for what should cost less than $50. Any suggestions?
Dustball
2016 B2650HSDC
Sep 15, 2023
494
356
Hudson, WI
A picture would help
To the OP- according to that thread, Weasler makes the coupling.
Maybe one of these two part numbers will work?
jleickman
TG1860
Mar 21, 2026
Highstreet
The discs in the K1211-01360 Flex Coupling are abt 4 ' in diameter and the bolt holes are abt 3/8". While I believe the discs in this illustration are made by Weasler as well as the Kubota discs, I believe that the Kubota discs were made especially for them and are not an off-the-shelf item. Thanks for the help.
jleickman
TG1860
Mar 21, 2026
Highstreet
I'd go to the local farm supply store and buy 6" of baler belting. They sell it by the foot. Fab your own.
Thank You! Never thought of that because round balers came into use after I had left the farm as a kid. Was never around them.
jleickman
TG1860
Mar 21, 2026
Highstreet
Cut your own out of a tire sidewall.
Tractor fixed. I cut two "pucks" out of a horse stall rubber mat from Tractor Supply with a hole saw and drilled the bolt holes. These were thicker than the original discs so I omitted all the washers except those under the nuts. The new coupler is stiffer but I don't believe that there is any more vibration than before.
