swivel ball on three point frozen
firstpass
L3000DT
Oct 22, 2017
14
Kooskia Idaho
I am attempting to adjust the three point hitch and found that the swivel ball of the vertical lift arm is frozen. What is the best solution to get it to loosen up.
Before I purchased, the tractor was exposed to the weather. I have soaked in penetrating oil with no luck.
Firstpass
firstpass
L3000DT
Oct 22, 2017
14
Kooskia Idaho
I have a recently purchased L300DT. I am beginning to service the tractor to get it ready for use. The vertical lift leveling arm on the three point hitch is frozen and will not allow for proper adjustment of the hitch. I have soaked the swivel ball in penetrating oil without any luck. What is the best solution to free up the swivel ball.
firstpass
1970cs
1,124
Grand Ledge
Try a mixture of acetone and ATF. Place the link in a vise and use a large screwdriver or smaller pry bar placed cross ways in the ball ID and just wobble it back and forth.
Pat
baronetm
L3901HST w/FEL, 3rd fnct. BH77 BH, 5' Bushhog, 6' BBL, 42" Forks, WoodMaxx WM-8H
Apr 19, 2017
122
12
South Central VT.
A little heat on surrounding area and ball from a Mapp Gas or Oxy/Act torch along with the previously stated soaking and a good stout pry bar or good raps with a brass hammer. No need to make it red hot, just warm enough to help break the rust. Then keep them oiled liberally.
1,874
What type of penetrating fluid are you using? I have had very good luck with PB Blaster
3,924
Mine have been like that since day one, oil grease and a bar and they loosen up to use and no worries,, then when you are finished and need to do it again same thing,, the more you use the 3 pt the more they wear in and the looser they become
