Stuck strainer B2150
Sabireley
B2150
Jun 8, 2020
I have a B2150 HST and want to change the strainer. The bolt is stuck and I am afraid to put too much pressure on it for fear of twisting it off. Are there any tricks to removing it?
First post BTW
Thanks!
SDT
Apr 15, 2018
3,684
1,408
First post BTW
Thanks!
I had difficulty removing the suction strainer on my B1750 upon first change. Could not remove it with hand tools on the ground.
Finally removed the left wheel/tire and removed it easily with an impact wrench and 6 point socket.
You will not twist it off.
SDT
Sabireley
B2150
Jun 8, 2020
SDT
Did you use an air impact?
SDT
Apr 15, 2018
3,684
1,408
I cannot remember.
I have both air and electric.
Either will work.
Use a six point socket and do not use an extension.
SDT
SDT
Apr 15, 2018
3,684
1,408
I cannot remember.
Either will work.
By the way, the strainer need not be changed, but only cleaned. It is permanent if not damaged.
SDT
