turck New member Equipment m5140, JD2020, ford 850, farmal 240 Apr 20, 2013 56 0 0 carthage, ny usa Jan 8, 2017 #1 the three point control lever started getting a lot harder to move yesterday while I was using my three point snow blower on a M5140. Is there any lube spots that I need to do?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,551 9,786 113 Sandpoint, ID Jan 8, 2017 #2 The control linkage has several pivot points, I would start with spraying those down with some good penetration lube. If that doesn't work you might have to adjust the tension on the holder for the control.
