Steering Upgrade
mtnplower
Kubota L5740
Jul 15, 2022
72
Sierra Nevadas
hey guys
I'm looking at upgrading to a M135GX or similar size tractor.
It looks like the steering is Hydraulic cylinder that transitions into a tie rod. That seems like a troublesome design.
Has anyone eliminated the tie rod and gone with a full hydraulic cylinder that connects straight to the wheel spindle?
5,109
hey guys
Its a proven design that has been used for decades by just about every OEM.
3,460
Is there a reason you want to eliminate having the "adjustability" of a tie rod?
I don't know how often they go bad on tractors, but vehicles regularly get 100,000+ miles out of a tie rod and they get subjected to relatively much "higher speeds" than a tractor.
Unless there is a some "special need" that I am not aware of, it sounds like a case of "A solution, looking for a problem".
8,640
hey guys
I think I've changed one of those joints and it wasn't from wear it was from someone hitting a stump.
You would have to come up with a real elaborate set up having 2 cylinders on pivots.
Now that sounds like a huge problem!
