Static in radio
gmbc
B2650HSDC ,bucket, Forks, Front Snow blower, MMM, Tiller, Land Rake
Mar 11, 2016
98
27
Dundurn, Saskatchewan, Canada
Installed LED lights now have static in Radio when running tractor. Where would I install a noise suppressor or resistor for lights . On each li=ght or is there a central spot on tractor
5,538
Only when running the tractor ? Any static with tractor NOT running but radio and lights on ?
'Static' is either airborne or in the wiring. If it's coming into the radio by the +12V feed, then 'suppressors' (L-C sections) should be added at the radio power input connector as well as each LED light.
If it's airborne aka EMI or RF, that gets real 'tricky'. You might try adding real ground wires form each LED light to the battery,also check that the radio has a GREAT ground.
It'd be interesting to see what's actually in the LED light. I'd think some 'active' component, perhaps a switching PSU, as devices like resitors or CC chips won't generate 'noise'.
sagor
Jan 9, 2017
287
65
Sudbury, ON, Canada
Critical question is if there is noise without the tractor running but the lights are on. If noise, then LEDs are likely the culprit. If no noise, then likely the LEDs may be overloading a circuit or taxing the alternator more than "normal" loads when tractor is running. Some noise filter at the alternator may help. Or, disconnect the LEDs, one at a time if possible, and check for noise. It may just be one LED that is bad.
Did you move any wiring for the radio? Is the antenna still connected properly to the radio? You can try RFI filters on the radio power lead. Those are usually a snap together type of ferrite "clamp on" filter.
lynnmor
B2601-1
May 3, 2021
1,499
1,245
Red Lion
I replaced all the incandescent bulbs in my travel trailer with LED's. Had some radio noise and lost all but the closest TV stations. Turned out the "better" LED's have a voltage regulator and the cheap ones have none. So I replaced them with the cheap ones and the problem went away. Supposedly, the voltage regulated have a longer life but that hasn't been a problem, and even if they failed the price is cheap. Just an idea, maybe an answer to the problem.
5,538
sigh...
this from the linked article..
As you might know, LED lights emit light by flickering hundreds and even thousands of times per second.
No that is NOT true, it is a lie, LEDs do NOT 'flicker'. If it was true then they couldn't be used for communications or relaying of data, here,there ,everywhere.
sagor
Jan 9, 2017
287
65
Sudbury, ON, Canada
sigh...
Greensville is basically correct. For LEDs that simply turn on and run, they do not flicker under DC power. However, if anyone has a dimable LED, there may be "flickering", but at speeds humans do not detect. Also, any LED powered by AC may have a 60Hz (50Hz) flicker, again not visible to the human eye.
LEDs that are powered by DC and have a dimmer of some sort usually use PWM, a pulse width modulated control. Those can run at a few hundred to several thousands of Hz and may cause RF interference. Usually one does not run those on mobile equipment, including tractors. So that is not an issue in this case I would think.
5,538
The proper way to actually power an LED is with constant current NOT a constant voltage(or PWMed). Dimming an LED by varying the current is easy and ZERO 'EMI/noise/static' is generated.
I've run LEDs on over 15 miles(yes, MILES) of copper wire, no issues with 'static'.
Before you buy any LED, take an AM radio to the store and have the sales guy turn on the light, hear what happens...
dlsmith
BX2230, LA211
Nov 15, 2018
1,255
817
Goshen, IN
A lot of cars with LED tail lights use PWM to simulate dual filament bulbs, They use a low(narrow) pulse width for the tail lights and high(wide) pulse widths for stop/turn lights.
5,538
US guv has just passed 'adaptive headlights' now.... ,gets around the no high and low beam law.
Think LOTS of White LEDs that have their individual brightnesses controlled by, yeah, yet another computer that communicate (sometimes) with all the other computers in the vehicle.
Just wait for the insurance rates to go sky high !! Each headlight will be over $1000 to replace.
WAS BANNED FOR NSFW PICS
5,143
When my wife ran over Bambi last fall, the headlight assembly without the bulb was $1800, and the LED fog light was just shy of $800 to replace. Neither came with bulbs and they were able to reuse the originals.
5,538
that's insane.. 1800 for what, 5 pounds of PLASTIC !!!
I know the rubber bumpers are pricey, kid next door fixes them, says some are 5K ! AND need to be painted too $$$!!!
While I have the 'nitty gritty' how they work details haven't seen a real price for the 'nextgen headlights, now thinking 3-4K might be a deal ? Course if they can't get the chips, they won't be available anytime soon.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
397
60
Wa
I bought and installed one of these on the power wire, where is exits the fuse block, for the rear work lights:
It did remove the static, but it also reduces the sound/volume. It is like a partial mute or for those that have the automotive radio that has speed adaptive volume, it is the difference in off/on of that feature.
I will check it out further.
5,538
Normally you'll place 'suppressors' at the SOURCE of the 'noise', in this case the rear work lights.
They only reduce noise in the wire NOT in the air.
I can't think of any reason as to why the volume went down,unless the radio has some 'memory' features,like presets and configurations.
Orange1forme
Dec 1, 2018
397
60
Wa
Why would there be a difference in the location of the ferrite core?
Would I really want to install it out in the weather?
I was going to put one on the radio wire, too. Not enough slack at the fuse block and did not want to deal with pulling the radio at that time. I may still pull the radio.
The sound drop happens with the lights being turned on even before the ferrite core. Now there is no noticeable static.
It is also only when I turn on the rear work lights. I have had both different and the same LED lights as the front on the back and both acted the same with the radio.
gmbc
Mar 11, 2016
98
27
Only when running tractor lights on. I have ferrite suppressors just all packed as moving. Just wondered if needed in line suppressors. Thanks all for input.
