starting
dstep105
Sherman, TX
I am having trouble starting my Kubota G6200...I have replaced battery and starter. The glow plug indicator does light up but just wont start. It turns over. What am I missing here?
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
34
Alberta
Start with the simple things. Is there fuel in the tank? Is the fuel shut off valve open? When was the last time the fuel filter was changed. Have you checked for fuel flow to the injection pump? Fuel to the injectors? Is there any smoke out of the exhaust while cranking the engine over?
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
If it has the electric fuel cut off solenoid, is it clicking when you turn the key just to the run position? Crack an injector line and crank the engine to see if you have fuel.
