Starting issues
Tweeter
L245DT
Feb 19, 2024
cincinnati
My LT245 has starting issues, sometimes the tractor will start other times it will not. After the glow plugs have been warmed and switch turned to start the lights dim as if there is a load on the battery but the starter does not turn. If I try again it intermittently does start. I s there a dead spot on the starter that would cause this ???
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,019
960
Amsterdam, NY
Inspect the ground from battery to frame - clean / tighten / replace as needed. Very common issue.
Inspect / clean /replace all connections to the starter.
Load test the battery, can read 12v until a load is put on it.
Let us know what you find and we can go from there.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
211
252
Stafford, VA
Bee-Positive is correct…after cleaning both battery cables (both ends) “load” test your battery (with your battery load tester or bring your battery to your local auto parts store and have them load test it for you…most likely the test will be done free of charge) a bad battery might provide the correct voltage at its terminals but cannot start your tractor with its inherent starting load.
