Stall Guard
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
316
137
Jefferson, Ohio
My first tractor was an L3540 HST that I bought 13 years ago.
I watched this video and thought about what I need this for.
I decided to try it. When mowing grass I am on cruse control. I have it at 6 MPH. When I hit heavy grass, it may slow down to 3 ½ MPH but it only loses 200 RPM.
If you have Hydro dual speed turned on it slows down too much.
SDT
Apr 15, 2018
3,681
1,406
Sounds like it is working as intended.
I experimented with Stall Guard while mowing with my L6060 but determined that I was better at controling engine load and speed that Stall Guard was and discontinued use.
When getting into heavy grass, stall guard would reduce ground speed to control load, sometimes to zero in very heavy conditions. It would also cause the tractor to buck or jerk as the load changed suddenly, e.g., mower discharges large load of debris, quickly reducing load, etc.
I expect that it would have been more effective while mowing relatively level areas with relatively constant PTO load, expecially if using cruise control but most of my parcels are not so regular and I never use cruise control while mowing.
6,653
Good post. I think that’s the best practical explanation of those features I’ve ever seen, and while I do see many of Neil’s videos, I hadn’t seen that one.
Obviously, my economy grade tractor has none of those features, so I suppose my interest is mostly voyeuristic; wondering what I’m missing. Now I know.
While I can see their utility for long sessions of loader work, for my purposes I’m not jealous for any of those features. Still, it’s amazing the performance capabilities of some of these relatively small machines.
Lowlysubaruguy
b7800 l4701
Oct 3, 2025
81
36
Big Island
Im so impressed with stall guard I almost have no regrets that I didn’t get a tractor with a cab.
I hunted a long time for the right used tractor with a cab. Time was running out I found a used L3560 with every implement I wanted but no cab. Price was right 240 hours. I was worried I was was going to miss the HP, this tractor was replacing an L4701. I haven’t used a pto devise in years so less of a concern on that angle. But I move dirt gravel and full 55 drums drag cars without suspensions around a steep lot.
I did side by side comparisons of the two tractors and the L3560 out performs the L4701 in everything i normally do. It also has ATA auto throttle advance which really puts the stall guard feature in a different class. Now I want a new tractor I was struggling with the cost v the use this tractor will see but I’m over it. I may order a new grand with a cab next year. I need to move some snow with this one it may be so much faster that maybe I can live without a cab.
