Speed Adj for Kubota T1670
man00
197
12
okla
Pulls strong but forward is kinda slow for sure, I notice if I push hard on the HST pedal I can get more speed.
070 or 110 is where I need to make any changes ? Could be some rod bent or something but the HST works fine other that that.
thepumpguysc
267
Sunny South Carolina
Get a buddy to mash the pedal to the floor..
I would disconnect it at the LEVER end{110}
& pull/push the lever all the way open BY HAND..
THEN lengthen/shorten the rod to meet the new hole location..
Pretty simple procedure.. good luck
man00
197
12
okla
Sounds like the plan, thanks
5,473
2,164
Neutral arm (170) has a set screw (180) that holds it to the shaft. Is that set screw nice and tight? Also look at #190 (bearing). It has to be free and in good condition. Seen lots of those gone/missing/broken.
