What is "splitting" a tractor?
leonard65
B2320 tractor
Mar 21, 2026
Sorry, Dumb question,
Ok, I have to know, what is splitting the tractor ?
3,029
never a dumb question!!
Basically a split occurs when the clutch needs to be changed. Sometimes other part need to be changed too. breaking the tractor from front to back is the split!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,190
2,846
Near Lancaster, PA, USA
Welcome aboard!
I'm no mechanic but I split my Ford 1210. It was easy because it isn't a big tractor but the basics are the same. Removed unnecessary things that would get in the way - in my case that was hood, fuel tank and battery. Then remove or disconnect anything that crossed the joint of the engine block/bell housing. Several wires and hydraulic lines. Support both halves of the tractor. I used a cable come-a-long from an overhead attachment point for the front and made a "kickstand" for the back half. Then removed the bell housing bolts and wiggle/pry it apart.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
597
619
Lake Almanor, Ca
It is really something you don’t want to happen…if needed, pay someone else to birth the clutch.😎
