Small tree transplant attachment
Yarg
L35
May 25, 2018
22
Catskills ny
Hello I have a Kubota l35 backhoe loader that I'm looking to get a quick attach so I could easily switch off implements
I need to transplant a lot of small trees 3in diameter and under..Apple and Hawthorne mostly. Was wondering what you guys recommend. I also am going to post this in the fabrication as I have a friend who's a very good welder. Thanks
BigG
Sep 14, 2018
1,951
773
West Central,FL
How about a link to what you found so we know what you are looking for?
8,743
Auger is good for potted trees, stump bucket for ground to ground movement. ;)
SidecarFlip
Banned
557
Exactly how I do it when I plant transplants. Little bit of fertilizer in the bottom of the hole as well, the some soil, the tree and more soil.
Yarg
L35
May 25, 2018
22
Catskills ny
I'm actually planting lots and lots of bare-root seedlings but I need to move some larger trees that are established. That is why I'm looking for transplant implent that would sct like a giant spade.
8,743
Yep, stump bucket is what you want! ;)
mikester
M59 TLB
Oct 21, 2017
3,878
2,522
www.divergentstuff.ca
Get at least a 36-42 inch wide scoop bucket for the loader. Apple trees have shallow and wide roots, you will be cutting a lot of roots on 3 inch if they havent been root pruned. Your machine will be too small to run a larger tree spade ie over 24 inch up front.
Yarg
L35
May 25, 2018
22
Catskills ny
Great point it would have been much better to circle them at least with a hand Spade for root pruning this'll pass autumn.
I assume stump bucket are all similar to guys recommended particular brand thanks
notforhire
Kubota L47
Dec 5, 2019
148
69
Meadows of Dan VA.
Because I don't have enough posts yet, I'm not allowed to give you a link to their website.:(
If you google MS attachments spade bucket, you should find the style I'm referring to.
I like this round bottom design over the flat bottom models. I find that it penetrates the ground easier. They also make a grapple model, (which is what I have). The grapple helps a lot in stump removal.
