Shotgun Bluing..
Tughill Tom
B3200
Dec 23, 2013
1,425
2,015
Turin, NY
I've used it as a touch-up on an old Pump action I had. If the gun has any value I would take to a Gunsmith and get done correctly.
Fro65
L3301HST, LA525, BH77, LP tiller, LP grader box, LP blade, BX2380
Dec 30, 2014
220
NorthEast Indiana
If you are intent on cold bluing, get some Oxpho Blue from Brownells and follow the instructions. Works great.
7,221
It’s been so long I’ve forgotten what I used, but Fro65’s suggestion rings a bell....
The gun I did was a beater that wasn’t worth much. The results weren’t great, but I was a kid and probably didn’t do a good job either....
4,915
John T, I used that stuff and after several try's I could never get it to work
3,441
I have used most of the stuff on the market at one or another, including the stuff from post #1. In fact I recently blued an entire rifle with it, with excellent results.
The only troubles I have had are that the metal isn't clean enough, and it must have the exact same finish all over. In other words, if part is buffed/polished with steel wool, part is scotch brighted, and part is emeryed, you will end up with three different levels of bluing.
3,441
Forgot to mention that I have had better luck with everything warm- not hot, but not cold either.
John T
2017 BX23S
May 5, 2017
1,217
750
under a rock
Came out ok for a beater.
Heat helped
But very hard to get even coverage.
Good enough for now.
John T
2017 BX23S
May 5, 2017
1,217
750
under a rock
Speaking of shotguns...
Browning - American Mallard, 12ga. 28" M/F #43978 - Connecticut Shotgun Manufacturing Company
John T
2017 BX23S
May 5, 2017
1,217
750
under a rock
Ive been to this place
They have a whiskey/ cigar room
Very nice place
And the guns selection would blow yer mind.
