Salt, Seed and Fertilizer Spreader
je1279
LX2610 w/ 60" MMM, LP 72" Snow Plow, EA Wicked 55" Grapple, and Woods 60" BB
Dec 6, 2020
723
454
Upstate NY
Does anyone know of a 3 point hitch spreader powered by either the rear pto or 12v that works well for both salt in the winter and seed and fertilizer in the fall/spring?
i7win7
Feb 21, 2020
3,254
3,789
Central, IL
You definately want one rated for salt, this $200 or so dry material spreader has to be dismantled, cleaned, repainted and lubed every fall. Expect I'll need to replace it in a couple of years.
TIP: get battery powered blower to clean excess salt off spreader / tractor after every use.
je1279
Dec 6, 2020
723
454
Upstate NY
Thanks for the tip. I was considering the Land Pride FSP500 but I've read that it's not great for controlling the drop rate when it comes to seed and fertilizer. It is also much larger than I need. I've seen some 12v spreaders for ATVs/UTVs but like you said it's difficult to find one designed for both salt and seed. I'd also need to come up with a way to mount it to either the quick hitch or the ballast box.
Benhameen
Jan 27, 2013
689
115
Southern IL.
No pics but I modified an electric seeder that was made for an ATV. It has a plastic hopper. I used the plug under the fender of my L3800 to power it. It attaches to the top of my quick hitch and the switch slides into the orange triangle holder. I put another triangle on the hopper itself. The only small issue I had was it throwing seed, fertilizer or salt😳 on the back of my tractor. A piece of card board fixed that.
WhitleyStu
B2601 LA435 FEL 60" MMM 60" Snow Blower FSP500 Spreader 5' Grahl Roller 40 spray
Sep 10, 2020
58
103
Indiana
We bought the 500 last year and it worked perfectly and easily can adjust discharge pattern.
