Safety switches
4,184
Get and Read an Owners Manual.
rScotty
Kubota M59, JD530, Deere 310SG
Aug 19, 2010
29
12
Colorado Mountains
The location of the start safety switches on a B7300?
There may be more, but you can always count on there being one under the seat to determine that you are sitting there, and one that is activated by the clutch pedal if you have a foot clutch. Those are the ones that cause the most trouble. Either one will keep the tractor from cranking.
Other places to look are the PTO actuating lever or knob, and the parking brake. The fuel system won't have a specific safety switch if it has a manual on/off lever on the fuel filter, but some models also had a fuel solenoid that would act the same way as a safety switch...that is, if the solenoid didn't actuate for some reason then the tractor would crank but not start.
rScotty
3,394
rScotty
Good advice, except you CANNOT always expect to have a safety switch under the seat. Neither my BX2200 nor my B2910 have seat safety switches...
