RTV900R shutoff
dennishowens
Kubota RTV 900R
Nov 19, 2021
9
Blackstone, Va
The disconnect of the solenoid wire stopped the fuse no. 7 (15 amp) from blowing. I have ordered a new solenoid. The wiring at the solenoid is brittle. Hope I dont have to replace the wiring. The connector wouldn't come apart. Had to snip the wire. Sixty years ago, I learned that you fuse the wire, not the load. Used to be an electrician. Be glad to get this running correctly as its interfering with my bird hunting.
Thanks for all the suggestions, especially the wiring diagrams. Happy Thanksgiving to all.
The new solenoid was installed and RTV still wouldn't stop. However it tried to cut off. Fortunately, the solenoid has slotted mounting holes and after some trial and error was able to find the sweet spot and all is well.
3,445
AND….the FUSE did not BLOW…. right?
3,445
