RTV520 Wiring Diagram
SPACTECH
RTV520, L3901, Z422-54
Sep 19, 2022
Central Florida
Hello all, I am new to OTT. I have a new RTV520 and would like to add lights, etc. I discovered several extra connectors on the harness with blue tape, but really need a wiring diagram or schematic. Any idea where i can find one? Thank you!
BX23-S,57 A-C D-14,
6,310
I saw/downloaded Kubotabooks.com has an RTV900 WSM ,chapter 8 electrical, has wiring diagram.
It should( ??) be similar, at least wire colours (??) to your unit ??
Might be a start of the adventure !
Jay
SPACTECH
Sep 19, 2022
Central Florida
Jay
Thank you for the information, and the quick response GreenvilleJay!
5,515
2,227
if they have blue tape on them they're usually accessory connections. Radio, light, etc.
if everything is working and no blowed fuses, then there is no problem.
kdparker
Kubota B2601 and RTV520
Nov 23, 2020
23
17
East Tennessee
I attached a PDF of wiring diagram for the RTV 500. Should be very close to same as RTV 520.
SPACTECH
Sep 19, 2022
Central Florida
Thank you kdparker, the design is very similar, but there are differences. I purchased a RTV520 WSM manual and "printed" the electrical drawing page to a PDF document. I attached the file with this message for anyone else looking for a RTV520 electrical drawing.
GovtMule66
Kubota RTV520
Feb 3, 2023
Bolt, WV
Thank you for posting the wiring drawing for the RTV520. Were you able to use the extra connectors that you found wrapped in the blue tape? My Dad just purchased a new Kubota RTV520 and we plan on installing a GPS Speedometer on it. I ran across those connectors you spoke of but I was hesitant to mess with them. Thank you for the help
SPACTECH
Sep 19, 2022
Central Florida
Hello GovtMule66, I love listening to the band of the same name! I decided not to use any of the connectors wrapped in blue tape. They are for optional equipment, and I decided instead to tap into the conductor feeding the 12V DC Outlet for my power source. Find the outlet at grid location D14 on the drawing. Notice the circuit is protected by a 15A fuse (A12), and is interrupted by a relay contact (B14). The relay is energized by the key switch (D9) in the ON position. For my application, this is a perfect scenario. Best of luck with your new RTV520. We are enjoying ours!
